meth nozzles
I run one on each side of the intake tube. Putting it behind the IAT sensor will allow you to create a meth reliant tune. If the meth quits for any reason, the computer will pull timing and help save you from damage. IAT vs. Spark is the table in HPtuners. Log the car and see where your IAT's are with the meth, at WOT for a good pull. Then put the threshold at the next increment above that to pull timing in the boosted region of the table.
