Spec 2+ Cluch -- Pressure plate not allowing block to mate with bellhousing
Hi all,
Have any of you run into an issue where the pressure plate springs are so stiff to the point where the block won't get close enough to the bellhousing to put any bolts in?
Crack the bleed valve and compress the bearing. This will relieve pressure allowing the bearing to fully compress and the transmission to slide on easily. If you have any further questions you are welcome to call me and i'll be happy to assist you. Thanks,
