LS1 Conversion into a 95 Camaro V6 Direct me to where I might need to go!
Old 10-16-2009, 08:10 PM
SlowLS1C5's Avatar
Default LS1 Conversion into a 95 Camaro V6 Direct me to where I might need to go!
Ok Is there any links out there on what I am going to need.
Off hand I know speartech will be able to get me the harness I need for adapting
but what about the fuel system, Can I use the stock lines, Pump etc.
Any links that have a write up of whats needed to stick a 02 LS1 Fbody motor in it? THanks!
Old 10-16-2009, 09:04 PM
blk96406's Avatar
Default Search
Im finishing up a 3.8/A4 to a carb'd 6.0/TH400 now, Ive done ALOT of reading and ALOT searching for info. When it comes down to it, its pretty painless........ If you have some questions PM me, Ill help if I can.
Jeremy
Old 10-17-2009, 07:02 AM
SlowLS1C5's Avatar
Unfortunately the carb route is easy. I need the efi route. Thanks though!
Old 10-17-2009, 10:59 AM
bczee's Avatar
If the fuel lines are 3/8", yes you should be able to use the line, The pump should be upgraded to at lease a LS1 rated pump or go with a Walbro 255 one.
It would also make it easier to use a LS1 K-member and mounts.. If you have a complete donner car.. all of the parts should be able to swap in or at lease be used. This is not so much a conversion or hybrid. but more of a upgrade for your 95 F-Body.
Engine Wiring would need to be intergraded to you body / dash harness. Speartech should be able to help out or one of the other sponsor vendors on this site.
Old 04-24-2011, 07:30 PM
Navarro6.0's Avatar
Jeremy
Hey man, I need some tips, and stuff about what I need or might need to put a 2005 6.0 in a 95 camaro that was a 3.8 v6 standered 5 speed, you can email me preston.navarro@yahoo.com or text me 9566242991 , itd help alot, its my first project and yeah, need some help.
Quick Reply: LS1 Conversion into a 95 Camaro V6 Direct me to where I might need to go!
