Rough Vibration in Car
Hey guys,
I have a 1998 Trans am. The car has about 140,000 miles on it. A couple of months ago I had several things worked on at once with it. I had one guy replace the ac compressor, knock sensor, and a few hoses. At the same time the car had a rebuilt transmission put in it (transmission had already failed so we trailered it between shops). So I have the car back now and it has a horrible vibration in it. I have put about 1000 miles on the car while trying to track this vibration down. The car vibrates real bad at any highway speed. However, it has to be in the transmission or engine because I can put the car in park, rev it up; and the vibration is there from 2000 rpm and up. The higher up in rpm you go, the more violent the vibration is. I’m trying to troubleshoot for the cheapest and easiest thing to replace first. Do you guys have any recommendations on how to approach this problem next? …..I really hope its not in the transmission…….
Thanks,
Thanks,
Hey guys,
Thanks,
Thanks,
