Question on Vic Jr with a accufab 4150
Im switching to a Victor Junior with a Accufab 4150 throttle body on it and have been trying to figure out what people are doing for a Throttle cable. ive been searching for a couple days and i haven't be able to find any pictures of even threads about it.. so if anyone running this setup has a picture of how the hook up the cable or part numbers for what i"ll need that would be awesome thanks in advance
I'm pretty sure some people are using lokar. I'll see if I can find something on it. I remember reading about this in the drag tech section a little while back.
edit: https://ls1tech.com/forums/drag-raci...bed-fbody.html
That should be what your looking for
I used a 36" Lokar. Be careful when cutting it to length because the sheath needs to be shorter than the actual cable. It is easy to cut the cable when trying to trim the sheath.
