Drag Racing Tech
What Throttle Cable for Carbed Fbody..
Old Mar 17, 2009 | 11:17 AM
1QuickT-A's Avatar
Default What Throttle Cable for Carbed Fbody..
Just wondering what throttle cable you guys with carbed fbodys are running? Does Lokar make one?? Thats about the last thing I need parts wise to get mine buttoned up. Thanks
Old Mar 17, 2009 | 11:24 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I rigged up the stock one. Interested in this as well.
Subscribing
Old Mar 17, 2009 | 11:37 AM
tomcowle's Avatar
Chevy s-10 v-6 cable with CSR bracket here.
Old Mar 17, 2009 | 12:21 PM
1QuickT-A's Avatar
I will have to check into that.. I have the CSR bracket already and I know where a couple of s10 parts trucks are hanging out at so...
Thanks for the info!
Old Mar 17, 2009 | 02:42 PM
Z28/2002's Avatar
You got any pics of the setup
Old Mar 17, 2009 | 05:07 PM
1QuickT-A's Avatar
Here is a pic of mine...
Old Mar 17, 2009 | 05:24 PM
Z28/2002's Avatar
Thanks, I gotta fix my stuff when I get back in the states
Old Mar 17, 2009 | 05:45 PM
Nabdrill's Avatar
I'm using the stock one... it's gonna look pretty good
Old Mar 17, 2009 | 08:08 PM
WHITE DEVIL's Avatar
i made my lokar fit i just cut it down
Old Mar 17, 2009 | 09:47 PM
BadBoo79's Avatar
Old hood release cable with a Lokar end & Jegs bracket:
Old Mar 17, 2009 | 09:52 PM
LS1SSII's Avatar
That is a funny looking TB.
Old Mar 20, 2009 | 11:19 PM
TJ's Avatar
TJ
haha.
thats a dominator carb. no tb there.
why did you mount it sideways?
Old Mar 21, 2009 | 01:33 AM
1QuickT-A's Avatar
Originally Posted by TJ
haha.
Because it wouldn't even come close to clearing the windshield over hang.. Take another look at the pic. Thats the whole reason I just sold my 2 stage nitrous plate kit and went with a fogger.. My carb wouldn't clear the windshield and you can't turn a 4150 flange carb sideways. Only the dominators..
Old Mar 21, 2009 | 06:39 PM
BadBoo79's Avatar
haha.
Hah hah. Yeah, LS1SSII's mullet must be a bit too tight.
As stated above, the carb is sideways for clearance. All it took was different floats (they are shaped like trapezoids). The carb is also jetted square.
With the Dart manifold picture, it would actually fit under the windshield, but we'd have to set the rear float off the car.
Recently I went to a Brodix manifold, which is taller, so now it would not clear for sure unless it was sideways.
Old Mar 21, 2009 | 07:19 PM
Camaro396's Avatar
Matt, I ordered a Lokar cable, I'll get the part number off it next time I'm out in the garage.
Old Mar 21, 2009 | 08:34 PM
southerntp's Avatar
Yeah I am needing this info also. I have the stock cable but I am putting a SBC with a 4500 dominator carb so I need something to make this thing work. If you guys would please pm me with part numbers and brands that I will need to make this thing work. Thanks
Old Mar 22, 2009 | 08:44 AM
TJ's Avatar
TJ
a dominator is good for anything then.
pretty slick setup.
is it a driver?
i have an aed that was square jetted, and i couldnt get it lean enough for cruising the streets. i even talked with john at aed and he said if i wanted a lean cruise, it would have to have a power valve. not even messing with the bleeds would do i what i wanted.
15.x a/f range is what i was looking for.
nice setup!
Old Mar 22, 2009 | 09:31 AM
BadBoo79's Avatar
pretty slick setup.
is it a driver?
nice setup!
Thanks! The car is race-only, but I guess with mufflers and insurance it could be driven a little.
With the old Aerosol carb I had, it drove well at part throttle. Now with the sideways Quickfuel, I have yet to work all the bugs out of it, but it seems ok at part throttle. I don't think there are provisions in it though for power valves, but I'd have to double check on that.
Old Mar 22, 2009 | 10:44 AM
TJ's Avatar
TJ
i had to send my metering plates in and have 2 holes drilled behind the power valve plug so when a power valve is installed it will pull fuel into the main body.
it was 35 bucks+shipping to do it.
before it would cruise in the 11's and just eat gas.
now im getting it tuned out to run in the 14-15 range, and the plugs are looking a lot less black.
whats it run?
Old Mar 22, 2009 | 12:39 PM
Camaro396's Avatar
I drive my car on the street with a dominator, but it loads up a lot cruising. Have to clear it out a lot.
