Drag Racing Tech
What Throttle Cable for Carbed Fbody..
Old Mar 22, 2009 | 01:22 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got a AED on my car as well with the Victor Jr. If you find the part numbers shoot them to me if you don't care.
When you guys put the new cable in did you go from the pedal all the way to the carb?
Old Mar 22, 2009 | 10:09 PM
TJ's Avatar
TJ
Originally Posted by Camaro396
I drive my car on the street with a dominator, but it loads up a lot cruising. Have to clear it out a lot.
check into getting the primary metering block drilled with a carb shop.
helped mine wonders.
its all a fresh setup, but at least its not cruising in the 10's anymore.
would dip into the 9's at time. ive been playing with it, but i need some air bleeds to go any further.
ive got it in the high 12's-low 13's on the wideband right now.
Old Mar 23, 2009 | 06:50 PM
southerntp's Avatar
anyone have part numbers for the throttle cable setup for SBC w/ 4500 dominator carb?
Old Mar 25, 2009 | 07:36 PM
southerntp's Avatar
come on guys. I have less than a month to get the car finished before our first race. I need to get everything ordered that I need.
Old Apr 29, 2009 | 07:09 AM
Sandmann120's Avatar
1Quick, what front drive are you using?
I thought somebody made and adapter/spacer to rotate a 4150 card sideways?
Ive already got a nice 4150 I'd like to use, and I can see it will be tough to make fit. Any thoughts? Maybe I'll just have to fab one up when I get home if I can't find anything in production.
Old Apr 29, 2009 | 02:12 PM
TJ's Avatar
TJ
dont know of an adapter. you could always have a machine shop ban saw the flange off and re weld it crooked.
if you have enough plenum not to disturb the intake.
dont see why it wouldnt work.
Old Apr 29, 2009 | 02:29 PM
Thats along the lines of what I was thinking. Should work. I've got the stuff to do it bvack home. Might have to experiment.
Old Apr 29, 2009 | 03:38 PM
Z28/2002's Avatar
Here are some shots of my 4150 mounted after the motor went in
Attached Thumbnails What Throttle Cable for Carbed Fbody..-266.jpg   What Throttle Cable for Carbed Fbody..-267.jpg   What Throttle Cable for Carbed Fbody..-268.jpg
Old Apr 29, 2009 | 05:33 PM
It's tough to tell from the pic. Is there clearace for a 1/2" plate under the carb?
Old Apr 30, 2009 | 10:41 AM
Z28/2002's Avatar
I had a NOS Powershot kit on there and had just enough room to get a breather on top. I don't know how tall the powershot plate is though.
I thought I had a picture of it but I must not.
Old Aug 27, 2009 | 04:11 PM
Jimmy P's Avatar
So what Lokar cable have you guys been using for this setup? Will TC-1000LS1 work? I have a Accufab 4150 with the Jegs GM style throttle bracket.
Old Aug 27, 2009 | 05:21 PM
  #32
JBM's Avatar
JBM
we used the lokar tc1000u with a PRP 4500 bracket set up for the lokar cable.
Old Aug 27, 2009 | 07:21 PM
  #33
1CAMWNDR's Avatar
I think the "LS1" cable has LS1 specific fitting for the throttle body so it will not work with a carb or 4BBL throttle body. Get the Universal 36" cable and cut it down to your length. Be ready to modify the throttle pedal also; the Lokar has a funky looking pedal attachment that is nothing like stock.
Old Aug 27, 2009 | 10:43 PM
  #34
Z28/2002's Avatar
I finally went to the junk yard and pulled one out of a 6 cylinder third gen car. It's about 24" long and works great
Old Aug 27, 2009 | 11:17 PM
  #35
Jimmy P's Avatar
Anyway you can take a picture of it? I am curious about the part that connects onto the throttle bracket.
Old Aug 28, 2009 | 12:16 AM
  #36
HotRod H269's Avatar
I have a 02 camaro that has a ZZ4 crate engine.I orderd a throttle cable for a 85 S-10 with a 2.8 V6.I use a quadrajet carb.I use a throttle cable bracket off a 79 corvette for a quadrajet.I did have to drill a hole in the throttle lever on carb though.But if works pefect and looks stock.the throttle cable is still available at gm dealers.
Old Sep 4, 2009 | 05:36 PM
  #37
Jimmy P's Avatar
So I ordered the 85 S10 carb throttle cable. Man this thing is short. Just from eyeballing it I would say its only 20 inches long.. Looks like it will reach but it will be very close.
Old Sep 4, 2009 | 07:56 PM
  #38
Z28/2002's Avatar
I think the one I pulled out of the junk yard was just at 24". I had some room to spare when I put it on but it works pretty damn good. The car should be down here in a week and I'll get some pics of the cable/linkage up
Old Sep 5, 2009 | 07:45 AM
  #39
trigger1's Avatar
We used an universal lokar cable when setting up my car. 4150 here, AED throttle bracket and universal lokar cable trimmed to fit.
Andd in that pic the throttle cable isn't even in the car yet. DOH! Too many pics of the car. I'll get one later.
Old Jun 13, 2010 | 08:59 AM
  #40
87Lt1Monte's Avatar
did you guys have to bend the gas pedal at all? ive heard on 3rd gens the carb would not open all the way without bending the gas pedal for more travel.
