lowering the oil pan, i need some help
Old 10-30-2009, 09:01 PM
ae13291's Avatar
Default lowering the oil pan, i need some help
hey guys, im trying to lower the oil pan on my car so i can get to the pick up tube bolt on the pump, i tried following the write up on LS1howto, ok i loosened all the main bolts around the perimeter but they were all 10mm, ls1howto says there is some 8mm and some 10mm did i forget to loosen some 8mm? and also there is a plastic cover around the starter area and i think there is 1 bolt that bolts into the oil pan do i loosen that too? i think its the inspection plate but its the one on the passenger side around the starter i already got the one on the driver side, and also the 2 transmission bolts on the bell housing looks to me like there going through the oil pan?? im not sure, i would greatly appreciate it if somebody can give me some insight. thank you guys
Old 10-30-2009, 09:21 PM
blubyu02's Avatar
there should be 2 13 mm bolts at the back of the oil pan as well, also there are 2 (hard to get to) on each side of the pan around the k member
Old 10-30-2009, 09:23 PM
ae13291's Avatar
i got those hard to get to ones with a racheting wrench and i guess all i was missing was the bell housing bolts right? those are on the rear. would i need to remove the other thing by the starter the inspection plate? thanks for the quick reply
Old 10-30-2009, 09:24 PM
blk96406's Avatar
Default bolts
I just stuck my head under mine, 14 bolts total to the pan itself. They are 8 mm diameter- good luck
Old 10-30-2009, 09:37 PM
ae13291's Avatar
humm dats funny, do you have a 1998 motor? or do u have a 2000+ motor? cuz my 99 has all 10mm bolts, thanks for the info 14 bolts got it. is that including the 13mm bolts on the bell housing through the oil pan?
Old 10-30-2009, 10:06 PM
blk96406's Avatar
Motor is an '01 Lq4. They are 8 mm diameter w/a 1.25 thread pitch, 10 mm head. I dont have any "13 mm" bolts in mine, but Ive got a TH400.......
Old 10-30-2009, 10:14 PM
ae13291's Avatar
hahah ok silly me i was referring to the head size, ok thats great thanks for the info. hopefully i can get that sucker to drop when i remove those 2 other 13mm bolts. cuz the pan is still on there pretty good after i hit it with a mallot a couple times
Old 10-30-2009, 10:26 PM
blk96406's Avatar
should, just becareful smacking it----with my "Jeremy luck" I'd smack it, crack it, not realize it till it was all back together and pissin on the floor!!!!! hahahahahahaha
Old 10-30-2009, 11:30 PM
01ssreda4's Avatar
If you havent removed the bellhousing bolts its not gonna drop. Get those then get back to us
Old 10-31-2009, 12:18 AM
ae13291's Avatar
ok guys i just removed the bell housing bolts and that sucka droped i also got the oil pump out but i barely managed to get the pick up tube bolt with a magnet, i guess i dident drop the pan low enough? i feel its gonna be like almost impossible to put it back in the way i got it out. im gonna try finding the bolt on the pan thats trying to cause trouble. or could it be that inspection plate on the pass side? but anyways im sure i could figure out the culprit in the morning if i look hard enough, im just letting you guys know. thanks again for all the replys. also do i use the black o ring supplied with the new pump or should i go get another blue one from the dealer? and im gonna try to install the pick up tube girdle to make sure i dont have problems later.
Old 10-31-2009, 08:12 AM
01ssreda4's Avatar
black one should be the right one.
Old 10-31-2009, 11:38 AM
KRAZY K 2000 TA's Avatar
i only left two rear most bolts in the pan or it will be near immposible on mine.
Old 10-31-2009, 12:45 PM
ae13291's Avatar
yea it makes sense now, especially with the girdle on there. would i damage anything letting the pan get that low while the pick up tube is bolted inside the oil pan?
