do you gain or lose hp when changing gears
Old 12-08-2003, 01:53 PM
Buff's Avatar
Default do you gain or lose hp when changing gears
i feel stupid for asking this question because i feel i should know and have seen this topic before.
Would you lose hp when changing from 3.42s to 4.10s in your car? and if so, how much on average?
Old 12-08-2003, 04:48 PM
Proud2bSS's Avatar
You really don't lose hp; you may lose the ability to apply all of it depending on several variables. What you are really doing (I think) with lower (numerically higher) gear ratios, is you multiply the torque from the motor at an incresed rate, depending on the increase in gearing. Your differential is a torque multiplier: ie 3.42:1 ratio takes 200 ft/lbs torque before the pinion and converts it into 684 ft/lbs of torque after the ring gear. A 4.11:1 ratio would be converting the same 200 ft/lbs to 822 ft/lbs. Applied against the same constants (car weight, internal and external friction, etc, etc), the torque used to move both vehicles will accelerate the one with the 4.11s quicker than the one with the 3.42s.
This may be simplified, but it works for me........until I stand corrected.
Old 12-08-2003, 05:37 PM
SPANKY LS1's Avatar
You will lose power to the rear wheels because the 4.10 gears require more power to turn than 3.42s, and are a less efficient gear. But, the car will accelerate quicker for the reasons listed above. So, they will hurt your dyno numbers, but will help your ETs.
Shawn
Old 12-08-2003, 06:17 PM
LSX Mechanic
Damian's Avatar
As said above, you'll lose some dyno power, but the gears will not actually take power away from the motor.
From what I have seen, 4:10's generally take 10 rwhp on the dyno..
Josh
Old 12-09-2003, 08:18 AM
Buff's Avatar
thanks for the quick lesson guys
Quick Reply: do you gain or lose hp when changing gears
