Starter not touching flywheel, Please Help
Well, everything is connected, all fluids are in, and my Ls1 is ready to fire up in its new Miata home. We hot wired the starter and it spun, but didn't make contact with the flywheel. So we pulled it out and hot wired it outside of the car. The gear slid out and spun fine, so we thought that because we swapped from an automatic to a manual transmission that maybe the starters are some how different. It seems that is not the case. So here is the question, what's wrong? Why is the starter working but not connecting to the flywheel? If you guys can imagine, we are sooooo close to making this sucker run for the first time. We really wanna see and hear this happen. Any help would be greatly appreciated, thanks.
Need more info about the starter issue. Can you take pics of the no contact when the starter is powered? The starter doesn't only spin, it also extends to engage to the flywheel. Did you buy a 168 teeth flywheel? Any shims added behind the flywheel & crank?
A few comments:
-Keep an eye on that water bump. The 4 bolt pulley indicates an old style pump. May want to get a new one. There may not be much life left in that one.
-What rear end is that? You need at minimum a Ford 7.5; 8.8 is better or an RX7 style. Also, need a ridgid rear end mount, not just poly mounts & torque tube.
-Need minimum upgraded front springs (coil overs). Fronts & rears preffered. It will be dangerous to drive the car on stock Miata suspension.
Build is comming along nicely. Just be responsable & careful while driving it. I call mine Death on wheels when operated in the wrong hands. In other words when driven carelessly. It's one thing to see the driving Court Judge about a ticket & quite another to be involved in a serious accident.
A few comments:
Awe ****, thought I was replying in the conversion section. How did it end up in the external area?
Mod's. please move to his build thread in the conversion/hybrids section. Thanks
I have seen starters appear to function normally on the bench but when placed in the car, they dont work right. A new starter has always remedied the situation.
A few comments:
A few comments:
