Minimum Need For 100 Shot?
What all would you guys recommend for a minimum of a 100 shot?
My buddy has a nitrous set up that he only used once that he is selling me for CHEAP. Its a base kit no safety items. What would you guys recommend me buying to make it safe?
I plan on putting it in the back on the transmission tunnel. So I wont need a bottle opener for sure.
Thanks
Thanks
window switch, bottle heater, purge, wideband, different plugs.
you could get away with less, but all those things would keep you safe and happy. the plugs and wideband i would consider necessary. the purge and heater are nice to have, and the window makes it alor easier to spray, and alot safer in most cases. just my two cents...
Our all out kit would certainly help you put together a quality setup
http://www.harrisspeedworks.com/prod...age=1&featured
comes with just about everything you would need to run a safe and reliable system
Microedge
Purge
Plugs
bottle heater
blow down tube
nitrous filter.
We also have a very nice looking tunnel mount for your bottle. Makes for a very clean looking install and has mounting locations for various types of bottle brackets.
let me know if you have any questions at all with our products or just in general
Microedge
Purge
Plugs
bottle heater
blow down tube
nitrous filter.
Ok so I do plan on getting an accessory package like the one listed above OR buying the stuff seperate. I also plan on going ahead and buying a wideband. I figure if/when I want to go FI I will be able to use it then. Also do you guys think I should go ahead and throw a fuel pump in there? Im thinking for $125 I should go ahead and do it just to be on the safe side plus it will be there for later if/when I do upgrade to bigger/better things.
Also if using the microedge....what would you guys set it to turn off at, if it runs too lean or too rich?
Also another quick question a buddy of mine says I will only get 2 sprays on a 100 shot in a 10lb bottle on the street. Is this true??
as for the cutoff you'll just have to see what your car is tuned to and what A/F it likes, then go from there.
no you'll get more than two, maybe he isnt running a bottle heater or something.
Also like mentioned, if you car is on stock timing it will be fine for the 100 shot. If its been advanced you will need to pull some out either through the tune or through an additional controller like our interface.
