A Little Different ABS Delete Install....
Old 11-05-2009, 08:56 PM
hiltsy855's Avatar
Default A Little Different ABS Delete Install....
I didn't like the master cylinder lines running across the top of the strut tower so I routed them behind & underneath. Should make it easier to work on the driver's side of the motor. I didn't use a line loc so that made it a little easier but I don't think it will be a big deal to add one down the road.
I just got done pulling the gage cluster and taping over the idiot lights.
SJM Steve - Thanks for putting the parts together for this project.
Old 11-05-2009, 09:30 PM
mitchntx's Avatar
Very nice, very clean install.
Steve, we've been e-mailing back and forth. This is pretty much what I'm looking for.
I would like a remote adjustment on the prop valve to be able to adjust while strapped into a race seat.
Old 11-06-2009, 05:50 AM
hiltsy855's Avatar
Thanks mitchntx. I'm sure Steve will be able to get you the fittings you need. I just bought some 3/16" brake line at Advance and bent them as needed.
Old 11-09-2009, 08:26 PM
Engine_HP's Avatar
looking good
Old 11-09-2009, 09:10 PM
35th SS's Avatar
shweeeet.looks good.
Old 11-09-2009, 09:23 PM
SJMMFGINC's Avatar
hiltsy855,
You're welcome. Glad you got everything setup the way you wanted. It turned out real nice. Mitch, if you need more help, please let me know. Since I don't check boards that often, e-mail is probably the best method of contact.
Old 11-10-2009, 06:23 PM
hiltsy855's Avatar
Thanks again Steve.
BTW - Pulling the gage cluster was not that big of a job. I had to drop the steering column a little bit to remove it but it came right out. I thought there would be a bunch of wires connected to the back but there is only a pin-type connector that un-plugs itself when you pull the cluster back. With the cluster removed there is only a rear printed circuit board to remove to access the little pods that the lights sit in. I just cut some electrical tape the size & shape of the pod and dropped it in. I covered the ABSINOP, BRAKE, & SERVICE VEHICLE and I also did the TSC & SKIP SHIFT lights since I disabled those a while back.
Quick Reply: A Little Different ABS Delete Install....
