How much Cam Duration will the stock LS6 intake support?
Old 11-12-2009, 12:24 AM
transamman1234's Avatar
Default How much Cam Duration will the stock LS6 intake support?
How much intake cam duration and lift will a the stock LS1 TB and LS6 intake support/tolerate?
Old 11-12-2009, 01:00 AM
Restricted User
FMS_FTW's Avatar
I'm not sure there is a limit of duration as there is RPM. The bigger the cam the better it will be with more RPM which is where you will run into limitations. Another problem before you would reach the max limitations of the intake/TB would be the PTV clearance and the ability of your springs to maintain the lift that would certainly come with a big duration cam.
Old 11-12-2009, 01:02 AM
lemons12's Avatar
Stock ls6 intake is good with a cam that only needs to spin to around 6100 RPMs to make its power.. Anything after that = FAST.
Ls6 intake starts hindering a setup aound 5900 RPMs.
