Frozen trans to block dowels...what worked for you?
Old 11-15-2009, 02:03 PM
SMS
SMS's Avatar
Default Frozen trans to block dowels...what worked for you?
Going to be doing a converter swap and am ready to drop the trans and pull the stock converter. Trouble is the trans will NOT let go of those dowels. I have all 8 bolts on the bench so there is no question that I missed a bolt. I have soaked the dowels on both sides with PB Blaster, let it sit for awhile, tapped on the bell housing to aid the penetration of the oil, but still no way will it come loose.
I tried driving a big screw driver in between the block and trans, but only seem to be digging into the aluminum and not separating the pieces. I have the starter off and the plastic inspection cover on the other side off, so I have a place to pry, but am afraid of cracking or breaking the bell housing if I get too aggressive.
Has letting the PB sit for a few days helped anyone? I also tried shoving the trans side to side with my feet on the tail hosing to get the most leverage, but most of the force is absorbed by the motor mounts. So, I came here to ask, What have you guys done to get the trans free in cases like this? Thanks.
Old 11-15-2009, 02:14 PM
heymoej's Avatar
ratchet strap..........from the rear end to the tail housing of the trans.
Old 11-15-2009, 02:40 PM
Tenured Member
SMOKY's Avatar
i used a butane torch on the dowels on a couple different ones. It usually does the trick
Old 11-15-2009, 03:23 PM
CayenneRedV6's Avatar
crow bar
Old 11-15-2009, 04:12 PM
LS1Silverado05's Avatar
Its been my experience that if you thoroughly soak them with some PB Blaster or equivalent and then try to use a rod of some kind to strike the dowels from the rear of the car, it will sometimes help to shock them loose.... (Im saying to actually get something IN the hole where the dowel goes to actually strike the dowel itself, NOT the bell housing)
I have also been part of the ratchet strap scenario but I am not a big fan of that one!
Old 11-15-2009, 04:43 PM
spanky_55amg's Avatar
these two guns, biting my lip, hanging my tounge and a can of elbow grease...
Old 11-15-2009, 04:49 PM
Some dont come off that easy....
Old 11-15-2009, 06:14 PM
SMS
SMS's Avatar
Originally Posted by CayenneRedV6
crow bar
I figured that one out, I just don't want to crack the bell housing prying on it. There's really no good place near the dowels to pry anyway, and there needs to be a gap to put the pry bar in. I think I'll try the propane torch on it tomorrow.
Old 11-15-2009, 10:02 PM
LS1Tech Sponsor
Slowhawk's Avatar
Torch works perfect.Don't know if the propane will get hot enough.I ussually use the map gas torch and the tranny falls off.
Old 11-15-2009, 11:54 PM
This sounds like the best route
Old 11-16-2009, 08:18 PM
SMS
SMS's Avatar
Got it! Picked up a MAPP torch at Lowes and put the heat to her. Still took a lot of pounding and prying to get it loose. What a job! Thanks for the tips.
Old 11-17-2009, 08:38 AM
scatillac's Avatar
Next time, once you get it warmed up, take a small birthday-cake candle, stick it into the dowel hole and let it melt a bit.
This also works well on cast iron (oil journal plugs, block drains, etc.).
Old 11-17-2009, 10:40 AM
Customizing Director
MadIceV8's Avatar
Ugh I hated those dowels! My car only has 28k and it was still a pain to get the transmission off.
Old 11-26-2009, 12:02 PM
capt.ld's Avatar
i used a ratchet strap over the tail shaft and rearend thightend the strap and pryed the trans right out,took me 3 days to figure that one out lol.what a bitch and a case of beer but i got it
Old 11-27-2009, 06:49 PM
02 BLK WS6's Avatar
Prybar and persistence worked for me. Still took 2 hrs to get it off the engine though.
