LQ9 Flywheel, Clutch, Pressure Plate
I need some help. I found a LQ9 from a 2004 Cadillac Escalade. It came with a flex plate. I want to convert it to use a t56 from a 2000 Camaro. Can I use a clutch, pressure plate and flywheel for 2000 Camaro for this set up? Would a flywheel, clutch and pressure plate from a 2010 Camaro work? I also need a pilot bearing. Thanks
