Just finished my m6 to a4 swap, dies when i put into reverse or d
i had my car tuned and flashed to a4. when i put the car into R or D it dies. the idle would surge below its normal level then die. is that in the tune? i think it needs more air or fuel when it goes into R or D mode.
ss3600 yank. i am not using stock tables. this was really a ruff tune that my guy did, us knowing that it needed more work. everything was working fine until i tried to use it today. it dies 4 out of 5 times when i go into drive.
Did it idle okay with the A4 at one point and then start acting up or was it surging as soon as the new trans was installed? It's probably the tune, but you need to make sure it's a not mechanical problem first. Can you post a log or tune?
ill try on the log. when i put the new tranny in it idled fine because i turned it on in neutral, this was before any tune or flashing. obviously no codes would be thrown cause its not looking for an a4 tranny and its just in neutral. after we tuned it i was driving it. it ran fine and all. then after a couple of mins i turned it back on and i couldnt move it cause it would die in on d. i finally got it to not die and idle fine in drive and drove into my garage. we tuned more on the driving part, and the park settings. but never the D part. this will be up next. i guess
