4l60e servo question
Old 11-30-2009, 11:36 AM
Restricted User
kalebm22's Avatar
Default 4l60e servo question
i have a 1997 trans am with a shift kit and a 3600 fuddle stall. i was wondering if i could put a heavier servo kit in the trans to make it shift a little fiirmer and hold a little more power. thanks for the help
Old 11-30-2009, 12:11 PM
LS1Tech Sponsor
performabuilt's Avatar
You already have the corvette servo the largest from GM however you could upgrade to and aftermarket billet though I dont really suggest this with the stock band as there is a risk that the band will break under the load.
I would suggest if you feel the need either a shift kit or possibly turing the shifts up a little in tuning (shift kit preferred) . However bear in mind the shift firmness did not change with the converter.The feel is just hidden due to the normal slip associated with a high stall converter. Its like a cushion in the drivetrain.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-30-2009, 12:14 PM
cause4panic's Avatar
If you have a factory 2-4 band i would not install a billet 2nd gear servo. You will rip the anchors right off the band.
Sonnax 4th gear servo yes but are you shifting hard into 4th?
Old 11-30-2009, 12:34 PM
Restricted User
kalebm22's Avatar
the shift into 4th is firm but its not hard by any means. they stall makes everything feel pretty soft so i wanted to make it a little firmer. i know i have the corvette servo already, but i thought maybe jet made a kit for my trans. i put a jet servo in my 92 700r4 car and was very pleased.
Quick Reply: 4l60e servo question
