SLP Diablosport tuner
Old 12-01-2009, 12:08 PM
LS12Fast4U's Avatar
Default SLP Diablosport tuner
Hey i was wondering if anyone has some info on this tuner? I want to know if it has a tune for headers on it so i can delete the rear O2 sensors? Also what other options are on it?
Old 12-01-2009, 12:17 PM
LS1Tech Sponsor
06MonteSS's Avatar
LS1Tech 10 Year
yes... the SLP version predators have slp-specific tunes on them that are meant to work in conjunction with their PowerPack bolt-on upgrade packages (headers, etc etc)....
so the rear O2's will be disabled in their preset/canned tune, since you can not disable them yourself in the adjustable parameters.
other things that you'll be able to adjust yourself include:
Timing Table 1000-3800rpm (+15/- 20%)
Timing Table 4000-4800rpm (+15/- 20%)
Timing Table 5000-7000rpm (+15/- 20%)
Fuel Table 1000-3800rpm (+/- 20%)
Fuel Table 4000-4800rpm (+/- 20%)
Fuel Table 5000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 12-01-2009, 12:39 PM
LS12Fast4U's Avatar
So if i get bigger injectors how do i change them with the tuner?
Old 12-01-2009, 12:42 PM
LS1Tech Sponsor
06MonteSS's Avatar
LS1Tech 10 Year
2nd one up from the bottom of the list.. . "adjust for different injector size"...
you'd go into "modify tune", and then you'd adjust the "injector slope" parameter to get your part-throttle fueling dialed in correctly...
__________________
Old 12-01-2009, 04:09 PM
LS12Fast4U's Avatar
I know which one on the list it is. I was just wondering the actual way you know how much to adjust on the slope. For instance if i do a couple WOT runs and data log it how do i know what to adjust by?
Old 12-01-2009, 07:13 PM
SSCAMARO02LS1's Avatar
Good Question....As far as Handheld Tuners---this 1 seems to be the best one out for the $$ right now ( plus its on sale right now ) I am not an LS1 Wizard or anything but from what I have been looking at and talking to shops about ( DynoComp in Arizona )
They say its the best, and they even use Diablo Software. I am going to get the Programmer then Install it myself to cut down cost....Then take it to a SpeedShop and have them dial it in with about an hour of Dyno Time and Air / Fuel Ratio / Engine Management Tuning which should run approx. $ 125 to $ 175.00.
Thats what I will be doing next week--DynoComp wants $ 1900 for Corsa Catback plus install, DiabloSport Software install, 1-Hour Dyno-Time plus 30 mins for Engine Management. I can order the Corsa, Diablo and install on my own then take it to get it Tuned and save about $ 300 - $ 400.00
Good luck man.
Old 12-02-2009, 12:15 PM
LS1Tech Sponsor
06MonteSS's Avatar
LS1Tech 10 Year
no...
you would do some normal steady driving/cruising datalogs to get the fueling adjusted correctly...
here's info:
http://diablosport.com/index.php?nam...iewtopic&t=917
so basically, you'll find out the average LTFT's... and for example, if your average ltft's are at +4, then you'll want to adjust your injector slope to -5%...
if your average ltft's are at -6, then you'll want to adjust your slope to +5%...
you want to get your average ltft's to be in the 0 to -2 range...
so, after you make a slope adjustment, put on about 50-75 miles, then do a new steady driving/cruising log (during the same/very similar weather conditions as the previous one), and using the software mentioned, see what your average ltft's are at after your adjustment you made....
__________________
Quick Reply: SLP Diablosport tuner
