Which transmission
Old 12-03-2009, 07:26 AM
khenry's Avatar
Default Which transmission
I am currently going through the build process of a 383 stroker / Single 78 mm turbo. I have an 02 ss M6 with a stage 3 monster clutch (with maybe 5K miles on the clutch) hardened gears and aftermarket syncros, 9" rear, and 3 1/2" steel drive shaft. Should the tranny/clutch hold? I'm expecting hp numbers in the mid to high 700 range. If not, any suggestions would be appreciated. I am opposed to switching to an automatic.
Old 12-03-2009, 07:50 AM
the_merv's Avatar
LS1Tech 10 Year
If auto then a built 4L80E should hold..or a Powerglide..which would be nice with that setup, depends on how hardcore you are about it.
As far as the T56..I would go with the Viper Build one from Tick.
Old 12-03-2009, 12:42 PM
khenry's Avatar
How much is the Viper build?
Old 12-03-2009, 02:43 PM
the_merv's Avatar
LS1Tech 10 Year
Look on their site..http://www.tickshift.com/
Old 12-03-2009, 10:01 PM
rabiddog's Avatar
tranzilla if you are going big and bad
http://www.rsgear.com/index.asp
Also
d&d's magnum
http://www.ddperformance.com/magnum.html
