Opinions on new engine combo....
I am looking for a little input from some of the experienced ls engine builders.
I currently run a stock bottom end 6.0 with twin 70mm turbos and on 14 psi with pump gas it makes somewhere just shy of 800 rwhp and runs 147mph in a 3250 weight fox body but looking to step things up a bit.
I will likely continue running the stock motor to see how far I can go with it while working on this new one.
Here are my thoughts:
Iron 5.3 block (Have all cleaned and mag'd already)
Stock 3.662 stroke crank(possiblybuy a 4" stroke )
Stock main caps pinned and studded
Wiseco 3.800 bore forged pistons
H beam rods
Custom grind comp 242/238 .610/.605 on a 115+3(Have already)
Ported 317 heads(Have already)
yella terra ultralite rocker arms
undecided on which intake manifold yet currently running LS6 with ported 78mm TB.
What I am thinking is this combo only works out to 328 c.i.d so I will be loosing 36 cubic inches but I also plan to spin this one a lot higher so I am hoping spool time etc will not be a big concern.
I am thinking the small bore gives more meat for better head gasket sealing surface and also leaves a LOT of block strength there. Run 20+ lbs and spin to 8k or so.
What do you guys think? This combo work? Looking to do something a little differnt then the standard 370/408 combo.
Thanks
Neil
H beam rods
Thanks
Neil
I do not like the 5.3 blocks bored to 3.905 and if I want to go bigger I will either need to retire this 6.0 or get another one. I just thought this would be a neat way to build something out of the box.
The pistons are a shelf stock piston from wiseco so they would be no differnt then running a 4.030 bore shelf piston.
I will not be buying heads as the ones I have work great especially right now.
I really dont think you gain that much block rigidity by not boring out a 5.3 iron block
to the LS1's 3.989 bore. The iron itself makes an already strong block design that much stronger.
I would think you would break rods and cranks before you split a factory Gen-III iron block
How do those twin T-70's spool up on your combo ???
They plot out like poop when you run the math on the compressor maps.
Way past the surge line on spool up. Do they act or sound weird on spool up ?
http://www.youtube.com/watch?v=gTEWw...eature=channel
I guess I'm kinda confused as to why you think a bored 5.3L block is more rigid/has "more meat" compared to a bored 6.0L block. You know they're not the same block, correct? Also, with 317's on a 5.3, I'd think that valve shrouding from the smaller bore would hurt the flow of your heads.
