Painting the intake manifold...help
Old 12-14-2003, 07:35 PM
HOSS's Avatar
Question Painting the intake manifold...help
whats up guys,
im scared really to take the damn thing off, but id like to paint it silver, how hard is it to take off, and what all does it involve, could i take it off and have it painted in 1 day, then put it on the next???any info is appreciated...just saw the thread of the engine bays, and there are some badass's in here...thanks guys
Old 12-14-2003, 07:54 PM
BlackWS602's Avatar
Removing the intake is fairly simple. You do need to be careful with the oil sensor as this is commonly broke when an intake is taken off. I bet if you start early and work all day, you could have the intake ready to be put back on the next day.
I had a walkthrough for this, let me try to find it
Old 12-14-2003, 08:04 PM
HOSS's Avatar
thanks bud...yea, that walkthrough would eb great
Old 12-14-2003, 08:17 PM
BlackWS602's Avatar
This is a friend of mine's website.
http://www.metalreviewcentre.com/TAframe.htm
Goto Project Resurrection. On the first page of that, towards the bottom gives you steps on painting the intake. Probably towards the top will give you info on removing the intake.
Old 12-14-2003, 08:35 PM
Scalpel's Avatar
ls1howto.com has all the info you'll need to remove/replace the intake.
Old 12-14-2003, 09:14 PM
onebadz's Avatar
http://ls1howto.com/index.php?article=5
There you go Ben hope that helps, lemme know when you wanna do it ill come help.
Wes
Old 12-14-2003, 09:25 PM
Fiery Features Director
Zangel's Avatar
Getting the intake off is the easy part. Once you get the intake off, make sure you clean it very well. We used a pressure washer on mine. Then you will need to sand down top of the intake as best as you can. I had Brains paint my intake with a spray gun. I think it turned out well. Here are a few pics:
Made these also and painted a bunch of other things...
Ending picture?
You can paint anything you want but I suggest leaving the stuff off the car until it is completely dry. I let everything sit for a few days before putting it back on.
Old 12-14-2003, 10:59 PM
Cheatin' Chad's Avatar
What did you do to prep the lower airbox and the radiator shroud?
Old 12-15-2003, 12:08 AM
JackZ28's Avatar
Sorry but that's too much silver!
If you prep it well, you can achieve great results. I was really happy with mine! Amazing what you can do with a rattle can with enough patience!
Old 12-15-2003, 07:30 AM
Zangel's Avatar
I realize that is alot of silver. I was actually planning on painting everything silver and then doing cranberry flames over it. I just ran out of time before the car show. It won't stay like that forever, but it looks alot better than it did before.
The lower airbox and the radiator shroud was really not that difficult if you get a good paint. I used PPG paint on everything under the hood. Sand down all the bad spots and use a SOS pad to scuff up the rest. Use a thick primer and then scuff it up again. You are now ready to apply the paint and clear coat. After everything is dry, go back and wet sand.
Old 12-15-2003, 09:02 AM
Restricted User
2001 Pewter WS6's Avatar
I used silver engine paint and it looks like an Aluminum Intake.
