fuel injectors rates
Old 12-11-2009, 07:20 AM
Phil'sC5vette's Avatar
Default fuel injectors rates
Do you know what the :
injector rated fuel pressure is for ford 30#, 36 #, 42 #
what the C5 fuel rail pressure is (I thought it was 58#)
F-body fuel rail pressure
2004-05 GTO fuel rail pressure
thanks
Phil
Old 12-11-2009, 10:15 AM
01ssreda4's Avatar
Is this a question?
My understanding is Ford's run 3 bar pressure which is about 45 psi. We run 4 bar which is about 60 psi. So that injector rated at 30 at 3 bar when applied to 4 bar flows more. Say 36 or so? I have never done the math though.
Old 12-11-2009, 10:38 AM
SOMbitch's Avatar
Originally Posted by 01ssreda4
Is this a question?
^^^^^^ correct
Knowing our 4 bar pressure is 58.xx and three bar is 45xx(IIRC) you can figure it out here >http://www.csgnetwork.com/fiflowcalc.html
Old 12-11-2009, 12:00 PM
i think this is the answer Im looking for
high the injector is rated at 39.15FP
the rail pressure is 58.. in the c5 and all ls f bodys.
the ford 30# injectors will flow 36 in your rail.
Old 12-11-2009, 01:11 PM
69LT1Bird's Avatar
Here is the Ford injectors.
http://www.fordracingparts.com/parts...asp?q=injector
Old 12-11-2009, 03:01 PM
another good page to save.
OK my numbers are right
Old 12-11-2009, 09:46 PM
tom falco's Avatar
Ok here is the scoop. All injectors are rated at flow capacity at 43.5 lbs of fuel preasure. So if you have an injector that flows 30 lbs at 43.5 lbs if you increase the preasure to 60 lbs. The injector will flow 35.2. A 36 lb injector at 60 lbs would flow 42.3 and a 42 lb injector will flow 49.3 at 60 lbs. Remember injectors should not exceed .8 DC to prevent lean outs. Remember all injector flow ratings are at 43.5 lbs not 45. At 45 lbs a 30 lb injector flows 30.5 slight difference. A 30 lb injector run at 58 lbs would flow 34.6 Hope this helps tom
