My Latest T56 casualty
if you have a high HP car with a T56, get used to looking at **** like this:
This is the guts out of my last one.... finally took it appart since I had some spare time
input shaft/4th gear and the cluster have been destroyed as you can see... this has happened before a hand full of times.
sucks because the cluster is the most expensive part in the trans, $600 just for that piece lol.
I am going to fix this so I can put it into my 94, the TA is missing 3 gears now
http://www.exoticperformanceplus.com...Car.php?car=11
At 809 rwhp in this GTO with a six speed, we snapped the pinion gear off the nine inch at this years LSX Shootout on it's first launch.
We got it back together and broke the output shaft in the transmission. Rodney at RPM Transmissions replaced the 27 spline shaft with a 32 spline shaft. How long it will last is anyone's guess at this horsepower level. Bob
spent the money on the 400 already, now just hope it holds
Roll racing is unavoidable here in Houston. I can still race up to 180ish... lol
I do plan to hit the track more often now though... thats the reason I gave into the swap, want some good numbers.
LOL
you don't have to worry until you do a big power adder. 7-800 rw it will be fine
