How can I make this temp switch work on a 6.0?
I have a s 6.0 with L92 heads that i am going to run a carb on. I need this temp sensor to fit the head. How can I do this?
Here...http://www.summitracing.com/parts/SU...0&autoview=sku
http://www.summitracing.com/parts/ATM-2281/
http://www.summitracing.com/parts/ATM-2280/
http://www.summitracing.com/parts/ATM-2283/
http://www.summitracing.com/parts/ATM-2282/
Or drill out and tap the factory sensor location in the head for that 3/8" fitting.
Buy an adapter to 1/8 NPT.
http://www.speedwaymotors.com/LS1-Wa...isplayId=20928
Thread the second ridge of the sensor below the existing threads for 1/8" NPT. I've got the same sensor, that's what I did.
Painless makes a switch that threads right into the stock head. At one point they had it available separately. Now they only sell it with a full relay-fan wiring kit.
http://www.summitracing.com/parts/PRF-30127/
Bastards
The one you picture looks like it could be lathed down and rethreaded to M12x1.5
Bastards
