Steering wheel air bag cover coming off
Old 12-14-2009, 11:59 AM
SilverV6Camaro's Avatar
Default Steering wheel air bag cover coming off
Has anyone had this happen? Is the only way to fix it to replace the air bag?
Old 12-14-2009, 05:03 PM
Spartan7's Avatar
Check the screws holding it down and see if they're loose. Should be allen screws (I forget what size).
Old 12-15-2009, 07:22 AM
Save the manuals!
wssix99's Avatar
I recall there are two torx screws going in from the back of the wheel.
When you mess with the screws, GM would advise disabling the air bag system. At a minimum, you'll want to keep your face/head away from the bag and off to the side.
