Quick emergency brake question
Old 12-15-2009, 11:51 PM
SS14PSI's Avatar
Default Quick emergency brake question
On my 97 Camaro, I had to remove the rear brake lines recently. Everything is re-installed, but still needs to be bled. My question is, will the E-brake still work even though the rears need to be bled? I wouldn't think so, because there's air in the lines, but does the E-brake work mechanically, like they do on drum brakes, or does it need to be bled before it'll work?
Old 12-16-2009, 02:06 AM
jattgunman's Avatar
if the 97's are like 98's and up bleeding the brakes shouldnt affect the ebrake, the ebrake is a drum brake style on my 01 ss.. idk if that helps
Old 12-16-2009, 05:37 PM
SS14PSI's Avatar
Checked it today....it works. /thread and thanks jattgunman
Quick Reply: Quick emergency brake question
