trashed bearings, machine work
I found some bearing in the oil pan today so its going to be pulled. Engine runs great just teh bearing problem now, what machine work is needed to fix this. Didnt pull the crack and rods yet so let say its both rod and crack bears spun
I dont understand what bearing you could have found in the oil except a needle bearing from one of the rockers. What did the bearing look like if its just a needle bearing from a rocker you just need to replace the rockers not pull the engine.
