high beam switch
Old 12-22-2009, 09:40 AM
teke184's Avatar
Default high beam switch
how do you change it?
is it accessible through the console? the highbeams WORK, but they won't stay switched on. if i hold the lever in, they stay on, but the switch just won't fully "switch"
what are the wires that operate it? i could always just rig a remote switch...i honestly use my highbeams a handfull of times a year.
Old 12-22-2009, 11:50 AM
slo_lt1's Avatar
theres a little plastic piece in there that broke off,unless you find it and somehow can get it to stay on there you cant do anything besides get a new multifunction switch
Old 12-22-2009, 07:32 PM
teke184's Avatar
good to know.
any idea how much the hole damn switch is??
Old 12-22-2009, 08:43 PM
eseibel67's Avatar
The switch is inexpensive - probably about $20.
Old 12-23-2009, 07:04 AM
teke184's Avatar
so you CAN get the switch? or are you refering to the whole lever
Old 12-23-2009, 09:19 AM
Rockstar
Johnny-LT1-runner's Avatar
The switch is cheap. Go to O'reilley's. It's located on the bottom of the steering column under the dash facing down. If it's not the switch it's probably the rod that connects it to the steering wheel. It's probably bent if that is the case.
Old 12-23-2009, 09:53 AM
teke184's Avatar
shweet...
appreciate the help.
the switch has slowly been going out. last year you had to pull on it at just the right angle or it would work. then all of a sudden...it never works. i can flash the highbeams, just not get them to stay on.
Old 12-23-2009, 09:59 AM
eseibel67's Avatar
teke: This switch is on a slotted mount. You can probably adjust it toward the steering wheel slightly to get it working for free.
Old 12-23-2009, 11:17 AM
slow96z's Avatar
Good call, that's what I was going to say.
Old 12-31-2009, 07:30 AM
teke184's Avatar
so where is the switch located again?
i tried to get into the "base" of the lever but could only get one small plastic cap off of it. not enough to get inside and check things out.
is there a switch located farther back? up under the dash more?
pics would be awesome!!
Old 12-31-2009, 07:47 AM
Spartan7's Avatar
It's in the same spot as the ignition switch on the steering column. The ignition switch is on top, the high beam switch is below it. Pull off the knee bolster and look up there, you'll see it.
Old 01-01-2010, 06:48 PM
Rockstar
Here's a pic of it, although in my experience it's located lower down the column and on the underside.
http://shbox.com/1/ignition_switch.jpg
Old 01-02-2010, 01:03 PM
teke184's Avatar
THANKS GUYS!!
you rock.
was a pain in the *** to get to. had to unbolt the bracket holding the column up, then unbolt the base of the column from the firewall. that allowed me enough room to enter through the top (by the steering wheel) and adjust it.
in playing with it i did find one thing strange.
if you tilted the steering wheel all the way up...the switch worked fine. but tilted down 1/2 way or more and it didn't work any more.
Old 01-02-2010, 04:58 PM
Rockstar
Originally Posted by teke184
THANKS GUYS!!
you rock.
Sounds like we have the same problem, I think it's the connecting rod, it's slightly bent or something.
Old 01-03-2010, 10:02 AM
Intimidator02SS's Avatar
Can't you adjust that switch a little? If I recall correctly, the bracket is slotted slightly so you can loosen and slide towards steering wheel and retighten.
Old 01-03-2010, 11:44 AM
teke184's Avatar
thats what i did.
ended up going to the end of the adjustment...hope i don't have any more issues
Quick Reply: high beam switch
