70 chevelle- ly6 /4l80e vvt boosted
Old 12-23-2009, 06:48 PM
chevellepowered's Avatar
Default 70 chevelle- ly6 /4l80e vvt boosted
yes its me again with another motor swap.. i do get bored with motor.. as some of you kno i had the turbo 5.3/4l80e 14 psi,,ran like a raped ape/..
well sold the motor sunday,,found a good deal on a ly6,,with 12 miles on it,, . dont kno which way to go with it yet maybe turboed or keep it n/a,,time will tell,, motor is already set in chevelle,went in real smooth.. even the stock exhaust manfoilds drop right in place,,had to grind 1/4 inch on passenger side off just for safty,, cleared it anyway.. but went in real nice.. 3200 stall is installed,,maybe manual valve body if i go carb route.3.23 posi rear... i will be swicthing the cam for aftermaket one.. other than that complety stock.. were here are some pics ...with the huge stock l92 heads!!! im excited bout this..
intake on there now is the ls1 one..just put it on there to see what it looked like. its for sale..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
thats right the big boy heads l92,,think they flow 320 cfm stock,,huge!!!
[IMG][/IMG]
6.0 IV
Old 12-23-2009, 07:02 PM
a big ole 88mm turbo would just be insane,, 8 psi,, might happen.. see if i can find any good deals..
has any one found out the limitations of a ly6 bottom end wise,,heard they come stock with forged rods,,true?,,,
Old 12-23-2009, 08:24 PM
i cant find much info out there on ly6..dang..
are ls1 cams diffrent from ls2??.. when i buy a cam i should buy a ls2 style..,, ive only delt with genIII motors.. i'll google some more..
Old 12-23-2009, 09:32 PM
71 chevelle's Avatar
howmuch are you asking for the intake and are you going to keep that water pump?
Wow that was fast. I seen this motor in the for sale section a day or two ago.
Nice you got a good deal.
Old 12-23-2009, 10:00 PM
intake is sold.. yea i sold 5.3 sunday bought ly6 tuesday,yesterday,,put it in today... yea im keeping the water pump.
Old 12-24-2009, 03:23 PM
just seeing what it would look like,,eye candy... thats a mpt70 with a .68 housing,, i kno way to small,it would choke it up big time.. plan on getting a 76mm or a 88mm if a good deal comes around.. if none then i'll just buy another mpt70 and do twins,, motor will be blowthru carb.. . 12 psi.. guy on truck forums ran 10's with his stock l76 with cam, with a procharger 12 psi i think..
if i do single turbo i'll do the truck setup,keep driver side manifold and make a log type on the passenger type.. real clean look..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
showin the clearence of the stock manifolds..
[IMG][/IMG]
picture of passenger side.kinda close to frame, but clears..
[IMG][/IMG]
[IMG][/IMG]
Old 12-24-2009, 07:10 PM
Jimbo1367's Avatar
I hope you are gonna keep the VVT.
Old 12-24-2009, 07:53 PM
82z28macdady's Avatar
damn you move fast man =D
thanks for the motor, gl on the next project and slap the turbo back on!
Old 12-25-2009, 08:18 AM
thanks ,,and good luck to you too... let me kno how it does..
and no i wont be keeping the vvt..
i would need a .96 housing to make this turbo work,,but it would stil run outa steam.. be instant boost tho..haha.
i seen some dyno numbers from a l76 in a pontaic g8,,same motor as mine just alum version,, 100% stock with twin turbo's 9 psi made 545rwhp. then upgraded fuel system and cam, ran 11 psi made a mind blowing 723rwhp.6xx rwtq.. http://www.g8board.com/forums/showthread.php?t=14444
there's another guy on youtube had a ly6 in his 70's model camaro ran twins made around 720 rwhp. e85..https://ls1tech.com/forums/forced-in...cs-inside.html
....http://www.youtube.com/watch?v=LnAE0...eature=channel
Old 01-07-2010, 06:56 PM
i found a ht60 which is a holset turbo of a big semi.. already looked it up and stuff.it will support 980hp for a gas motor.. this thing is massive.. also had a ht3b ..ht55,,but the ht60 flows the most..
another guy had one on his 355sbc,,ran in 9's with it..so it looks promising..or buy another mpt70..he wants $300 for ht60,think i'll buy it any way and do twin compound on our ole 12v cummins..
Old 01-08-2010, 01:31 AM
downtowncb's Avatar
This should be cool!
What the **** happened to your crank pulley?
Old 01-08-2010, 11:04 AM
lamdenali's Avatar
Did you have to do any Mod to the tranny tunnel ? am putting a 4L60E in the same car tonight. Did you drop the motor and tranny in one shot or you split them?
thx Lenny
Old 01-08-2010, 02:03 PM
crank pully,,, i recieved motor like that... lil worried bout it,,i'll find out,,
i have 4l80e which is pysically bigger than 4l60,,i put it in all togeather,,yours should fit..i didnt do anything to trans tunnel..lil tight,,,.. i never like pulling trans alone.. to much of a hassel to put it in... but i pull motor alone..
Old 01-08-2010, 02:55 PM
6D9
6D9's Avatar
Cool build! I was thinking about going with that same motor/tranny combo. What kind of power you looking for out of it NA??
Old 01-08-2010, 07:34 PM
well there a kit for vvt,that makes 480hp.. but its exspensive.. if i stay n/a i would be getting rid of the "vvt" and break 500 mark.. and blah blah about keeping the vvt,, if you want it then you keep it,""for all those vvt freaks""..,dont tell me to keep it,, some people have def opionions on vvt..i dont care about it.. i'll only keep vvt if i go boosted and leave stock cam in it,, think right now as i sit,im going to run the mpt70 and try .68 housing..yes yes i kno to small.. probly have boost creep.. i'll just get bigger wastegate.. should have killer torque real low rpm.. put stock tq convertor back in it..
i'll need to invest in some good tires!!!!
Old 01-08-2010, 08:12 PM
bonecrrusher's Avatar
This turbo setup going to have a phalic looking intake again?
Old 01-09-2010, 04:09 PM
big as i can get it..with out it being redicilous....
man its hard as hell to track down a factory harness for this beast.......gonna try to mod it myself,,"standalone" or send it off..
any one have a local junkyard with 08' truck harness with vvt..would greatly help..or a website to junkyard..
tried looking around ,saw the ls3 complete standalone kit for around $850 which sounds like an awsome deal,, but it doenst have vvt,, if i cant find a vvt harness and ecm ,then i'll just convert it ls3 harness..
and im not gonna pay a arm and leg for a custom harness..
Old 01-09-2010, 06:23 PM
Jimbo1367's Avatar
there is one on ebay . Better buy it before I decide to LOL. http://www.cgi.ebay.com/ebaymotors/2...item5d2727b90d
Old 01-09-2010, 06:24 PM
Jimbo1367's Avatar
http://cgi.ebay.com/ebaymotors/2007-...item5d2727b90d
Old 01-10-2010, 09:36 AM
lamdenali's Avatar
What pan did you use ? .I had the truck pan and it hit the center link ,look like it is too low, what motor plate did you use ? I have S & P plate with stock motor mount.
Quick Reply: 70 chevelle- ly6 /4l80e vvt boosted
