compression ratio help, please
I need help in calculating a compression ratio. I have searched and found formulas but I can't get it to work right. Please help if you could.
These are the details:
Stock 5.7 Block
Forged Flat Top pistons
4.8 heads (209cc intake/63cc chamber)
Valves 1.55/2.02
Stock 5.7 Block
Valves 1.55/2.02
LS1Tech Premium Sponsor
Are your pistons in or out of the hole? How much? What bore size are the pistons? What head gasket are you going to run?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I am trying to get a rough estimate for CR ratio. I was told that my cam was great for a turbo and I figured I already had forged pistons and rods.
Assuming the CR Ratio is around 10.5 : 1, is this too high to run a turbo?
Pistons are level with the top of the block. Pistons are factory bore and I do not believe they have valve reliefs. Not sure which head gaskets yet.
