Hatch release
Old 12-31-2009, 02:31 PM
D's Hawk's Avatar
Default Hatch release
I have to press my hatch release once, wait a second, and then press it again to be able to open it. When I press it the first time, it pops the hatch. Second time, it actually lets me raise it up. Is this normal? If not, what do you think the problem is?
Old 12-31-2009, 03:47 PM
nemss1's Avatar
mine did that as well. its caused by the spring not strong enough (not enough tension) from getting worn out. easily fixed by using a stronger spring or just piggy-backing the stock spring with another spring behind it
Old 12-31-2009, 05:26 PM
...with cheese.
Armageddon's Avatar
Adjust the rubber bump stops up to keep a little pressure on the hatch
Old 12-31-2009, 06:38 PM
nemss1's Avatar
Like Armageddon said, u can do that also
Old 12-31-2009, 08:10 PM
+badss+'s Avatar
http://www.installuniversity.com/ins...sity/index.htm
Old 12-31-2009, 08:11 PM
+badss+'s Avatar
Explains it all. Gl
Old 01-01-2010, 12:17 PM
D's Hawk's Avatar
thanks a lot for the info guys! I am on my way to home depot now, easy fix. Thanks again.
Damien
Quick Reply: Hatch release
