LS1 Advice
LS1 Advice
So i had to pull the top end of my motor apart because of a hung lifter and with 114k i decided to pull the motor and do a rebuild also. I want to put a set of heads on it and was thinking about some LS6 patriot heads. I was just wondering if anyone has a similar setup or what you think i could goin by going to these heads. My cam is a Thunder racing custom grind 233/236 .648 .601 with a 111.6 lsa I have a 3600 stall with 3:73 gears. Im thinking about going to a 4k stall. Thank you for any help you can give.
Patriot, TEA, Texas Speed, Tick Performance, VA Speed, and I'm sure some other prominent sponsors on here will all offer a ported LS6 head that's similar in flow and quality of parts. Some may have a more updated port design, but talk to the ones nearest you or that you already know and go with the one you trust the most. This is just a factory casting and if you're comparing vendors all with proven CNC port programs you really can't go wrong here.
I will add that if this is mostly a street car where driveability is a big concern, you may consider a ported 5.3 head instead as the ports are smaller than the LS6 and offer a little more low end.
Jason
Jason
Thanks for the advice ill look into the 5.3 heads. Yes this is a street driven car buy not a daily driver maybe once or twice a week depending on the weather. Any more help?
We offer both factory and aftermarket casting heads to get you setup with just about anything you need. From PRC 2.5 5.3L heads and Stg. 1 and 2.5 LS6 heads to our 215cc and 227cc aftermarket heads, we have something to work on just about any combo and any budget. We also have all the bolts and gaskets to complete the job as well! Give us a call or shoot me a PM with any questions you have an we'll get you fixed up!
Thanks!
Jon
Thanks!
Jon
