Quick T56 Compatibility Question
Old 01-05-2010, 11:23 AM
BrownBoy's Avatar
Default Quick T56 Compatibility Question
Hello guys and gals, I've just got a quick question.
Will a T56 from a 2002 Z28 Camaro work with an LM7 (5.3L block from a 2000 Silverado)?
Will I have to change the bellhousing and/or the output shaft?
Thanks in advance!
Old 01-05-2010, 11:55 AM
530sx's Avatar
I think you'd be fine with an ls1 f-body tranny. I'm not positive but I think the only LS t56 tranny that has a little bit different output shaft (longer or shorter I forget which) is is the one from the the 5.3L SSR
Old 01-05-2010, 12:03 PM
1989k1500's Avatar
You'll be fine with the 5.3 and f body t56. The 5.3 is an LS based engine just like LS1s, LS6s, etc
Old 01-05-2010, 12:12 PM
BrownBoy's Avatar
So if I'm using an LS2 clutch/flywheel with the camaro T-56, I wouldn't need to buy any other converting parts right?
Old 01-06-2010, 12:23 AM
1989k1500's Avatar
Nope, nothing. Thats what HellbentS10s last S10 was, 5.3 with LS2 flywheel and clutch and a gto T56.
Old 01-06-2010, 12:49 PM
BrownBoy's Avatar
Sweeeet! Thanks for the help Luke!
