Do I need the stock oil pressure switch for the engine to work?
I cleaned up my harness per Brenden's lt1swap information and noticed I removed the plug for the stock 2004 5.3 oil pressure switch.
Do I need this hooked up for the PCM to fire the injectors?
I am adding the correct switch for my guages in the boss on the side of the oil pan.
Is the stock 5.3 oil pressure switch needed or can I do away with that?
