LS6 Intake
Old 01-08-2010, 09:42 PM
caseypryan's Avatar
Default LS6 Intake
Would you guys agree that an LS6 intake only makes a difference of about 4rwhp on a 2000 SS?
Old 01-08-2010, 10:04 PM
Blackhawk777's Avatar
From what I understand, it's closer to about 10rwhp, but I could be wrong. It doesn't really overly shine until you get different heads and a aftermarket cam profile.
Old 01-08-2010, 10:40 PM
caseypryan's Avatar
Yeah I know it would make a bigger difference with heads and cam, but GM only increased the horsepower rating by 5 once they added that. I realize GM under-rates, so maybe someone could back up blackhawk777?
Old 01-08-2010, 11:06 PM
Quik Sand's Avatar
It will do better than 4whp even on a stock cam. I was at 331whp with mids, cutout, lid, pulley. Believe i went up to low 340's with the LS6 intake, I want to say like 343, netting me 10-15whp with those other mods.
Old 01-08-2010, 11:49 PM
LSX Mechanic
Damian's Avatar
I dyno'd an LS6 intake on my own car back in 02'ish. It made 9 more rwhp with zero tuning adjustments. With today's tuning knowledge/tech it probably would have been closer to 12-15rwhp. This was on a stock internal 98 FYI.
Old 01-09-2010, 12:04 AM
caseypryan's Avatar
Thanks for the help guys, considering investing in one!
Old 01-09-2010, 12:34 AM
01ssreda4's Avatar
As the intakes were introduced the factory cam got smaller so there's your reasoning for the only 5 hp increased in advertised power.
Old 01-09-2010, 09:03 AM
Pontiacerator
RevGTO's Avatar
It netted me a consistent .05 at the track. But I also gained throttle response throughout the rev range in everyday driving. Definitely worth it.
Old 01-09-2010, 09:36 AM
AFTICA's Avatar
It gave me a full tenth at the track back when I had a small 221/221 cam.
Old 01-09-2010, 11:43 AM
El_TransAm98's Avatar
Porting the intake throttle body will give u more hp!
Old 01-09-2010, 11:54 AM
hlaalu's Avatar
i noticed a big difference after the install and tuning.
Old 01-09-2010, 09:39 PM
hcb1700's Avatar
I read somewhere in a magazine or something that the reason the 01-02 Camaros didn't make more power then the older LS camaros because they were given a smaller lift cam, to make up for the addition of the LS6 intake, so that they could make the same power as the older LS Camaros.
Old 01-10-2010, 11:46 PM
caseypryan's Avatar
I knew they made the cam size smaller so all that does make sense.. so an LS6 intake makes a bigger difference in 98-00 camaros. That makes sense.
Old 01-11-2010, 06:14 AM
toadzq8's Avatar
I saw 7 RWHP on the dyno with just bolt on's on my 2000 SS with the LS6 intake swap.
Old 01-12-2010, 05:46 AM
fjb78's Avatar
I put one on with a ported throttle body and noticed a big difference.
