What all do I need for a fuel pump change
Guest
Posts: n/a
The Racetonix pump and hotwire harness will make the install very nice and the instructions are good too. If you do plan on doing the trap door mod then here is a good link to follow http://www.taekwondoplus.org/z28/fuelpump.html
if you cut the car make sure you are sure you want to, you can't go back. If you cut it I did mine in 2.5 hours with the hot wire and that was the first time with a hot wire kit. If you drop the tank, add hours depending on the contion of the cat "rust". hoist would help alot but not everyone has one. have fun. But other wise pretty easy.
LS1TECH Sponsor
Its not horrible to drop the tank...except on a 98. Either method will work, but just be very careful cutting if going that route and be sure to clean the tank off prior to opening it up. You don't want all that crap dropping into the tank.
Nick
Nick
