A/c problem
Old 01-11-2010, 07:43 PM
SLIVER-SS's Avatar
Default A/c problem
hellooo
In my 2000 camaro V8 when i accelerate, the air diverts to the floor vents and once you ease off the pedal it returns to the dash vents as normal.
today i turn the AC on and air is only coming from the floor vents only.
how can i fix it ???
Old 01-11-2010, 08:07 PM
LS6427's Avatar
You'll have to make sure your vacuum lines over by the PCM are all ok, and not cracked or dry-rotted. Its a little "T" fitting with pretty small black rubber hoses attached. I'm pretty sure they control the vents and how the air is directed.
Unless your talking about WOT runs....then the air will stop blowing through the vents until you come off the gas pedal. But the air should then return and start blowing again out the vents.
Old 01-11-2010, 08:52 PM
SLIVER-SS's Avatar
i will have to check everything to find the problem. the problem not at WOT its when im driving normaly.
if anyone have pic's that would be great .
thank u ls6427
