Detonation at High RPM
Old 12-19-2003, 07:58 PM
a5ltrbtr's Avatar
Default Detonation at High RPM
Everyone:
My symptom is I have audible detonation from 5000 RPM to redline. It is hurting my top end. It has done this since I owned the car. It is a 2000 Camaro SS with 6-speed. It is stock except a K&N filter. If I add a can of 104 Octane boost, it mostly goes away.
Where should I begin?
Thanks!
Old 12-19-2003, 08:29 PM
DaveSchott's Avatar
Originally Posted by a5ltrbtr
Everyone:
Thanks!
To start, you need to use a data recorder like autotap to validate what you are hearing - and afterwards to verify that you've cured the car since not all detonation can be heard.
Old 12-19-2003, 08:45 PM
WS6FirebirdTA00's Avatar
i had the SAME EXACT problem on my 00 WS6. i took off my egr valve, put in new plugs and wires and a 160 deg tstat, and well got it tuned right and it is perfect now. its a PITA but 2000 seems to be the trouble year, i think they ran the car a little leaner then...
Old 12-20-2003, 09:59 PM
NoGo's Avatar
I had the same on mine when it was mostly stock.
My problem stemmed from the PCV system sucking in GOBs of oil and causing carbon buildup in the cylinders.
Some top end cleaner band-aided this problem from oil change to oil change, but my basic problem was oil ingestion via the PCV.
Old 12-21-2003, 01:08 PM
Texas Terminator's Avatar
MIKE! I LOVE THE GOLF CART!! F!#$ING HILARIOUS!!
if you want to get real crazy, do the LS6 conversion. it's real easy.
Old 12-21-2003, 01:55 PM
haha yeah that was fun at the beach after it got done POURING! had to take a pic of that one lol. where can you get the write up/ parts for ls6 ocnversion, and what does it do?
Quick Reply: Detonation at High RPM
