6.0 wont do burnout,Torque Management
Old 01-12-2010, 12:29 AM
supershift67's Avatar
Default 6.0 wont do burnout,Torque Management
I have a 2007 6.0 in my chevelle with a 4l80e. 4.10 gears. If you try to power brake it with M/T et streets it will not spin the tires at all. The car seems to run good and has good power after your rolling but thats it. I am used to a big block chevy and it used to roast the tires with a blip of the throttle. My brother has an ls1 in his 81 camaro that will fry the tires 1st thru 3rd. I am wondering if the programmer left the torque management in and if the T/M could cause this. My 6.0 truck is the same way but my 5.3 yukon will do a good burnout. Thanks guys. this engine is all stock also.
Old 01-12-2010, 12:32 AM
chevellepowered's Avatar
isnt this the ly6 motor??? 07' right..
if so you using the e38 ecm e67... what ecm you using..
Old 01-12-2010, 02:07 PM
this is an lq4 engine.317 heads and no vvt. I do have a stock convertor also
stock ecu programmed by wait4meperformance.
Old 01-12-2010, 03:19 PM
Atver300's Avatar
Are you using the drive by wire or a throttle cable?
Old 01-12-2010, 04:29 PM
GA95DCMSS's Avatar
Is your trans linkage adjusted correctly? I had the same problem, turns out mine was half between D and OD when it slid into OD.
Old 01-12-2010, 11:54 PM
drive by wire
Old 01-12-2010, 11:57 PM
the trans linkage is good. shifts good through all the gears. Maybe it just doesnt have enough power. It just seems weird that my 01 gmc truck wont spin the tires either but my 03 yukon will with a 5.3 engine. that is why I thought it might still have the torque management turned on.
Old 01-13-2010, 10:16 AM
cyamaha2007's Avatar
my 2003 tahoe will not spin over the tires for anything its a 5.3
Old 01-13-2010, 10:44 AM
Atver300's Avatar
Originally Posted by supershift67
drive by wire
I think there is a table in the computer called brake torque management that wont allow the engine to make but a limited amount of either horsepower or torque when the brakes are applied. Basically even though you are flooring it the throttle blade isnt opening very far.
Old 01-13-2010, 10:49 AM
the_merv's Avatar
^^Same thing I've seen from reading around here..damn electronics won't let you have any fun..lol
Old 01-14-2010, 12:01 AM
ill have to check that out. thanks
Old 01-14-2010, 02:07 AM
ZTwentyAteU's Avatar
thats what it is, that or the ETC control.
if you log a run, when you hit the gas and try to brakestand it, it will cut throttle position back to 50% or try
Old 01-14-2010, 10:38 AM
what do you use to log your runs with,what program? thanks
Old 01-14-2010, 11:10 AM
CoolAid's Avatar
Look into HP Tuners.
Old 01-14-2010, 05:54 PM
Jimbo1367's Avatar
Is there anyway to over ride this? This is just DBW, correct?
Old 01-14-2010, 11:30 PM
the_merv's Avatar
You have to Tune it and adjust them tables.
Old 01-15-2010, 09:28 AM
ls1nova71's Avatar
Have you tried unhooking the brake switch or manually depressing the switch so that the brake lights don't come on (and so the PCM thinks the brakes are not on) then try to power brake it? Would tell you if that is actually your problem. Just a thought.
Old 01-15-2010, 10:29 AM
the_merv's Avatar
^^There ya go..
Old 01-15-2010, 07:59 PM
Atver300's Avatar
That car should blow the tires off without even touching the brakes. I'm guessing its still has all the torque management in the pcm, or the etc tables aren't right. Get someone with hptuners to pull the tune and post it up.
Quick Reply: 6.0 wont do burnout,Torque Management
