Changing the power steering pump
Old 01-12-2010, 04:56 PM
Zerokube's Avatar
Default Changing the power steering pump
Can anyone post a link on how to change it or tell me what i need to do? thanks
Old 01-13-2010, 09:38 AM
CamdLS1'00SS's Avatar
i can explain it, been a while since i did 3 on my car...sorry if i miss a step,
going to need to aquire a power steering pulley puller tool apulley installer kit, (autozone/advance), and a drain pain, and want to place a plastic bag/cover over the alternator so the fluid doesnt leak on it and mess up the brushes (thatd be alternator #s 1 and 2 for me lol)
remove the accessory belt
pull the pulley off
place pan underneath car under pump
remove PS lines, one is held on with a cheasy spring clamp (ideal to replace with a worm clamp), the others a fitting around the back of it, might be tight
remove the 3 bolts holding the pump to the bracket
fanangle the pump out and put the new one in reversing removal procedure
dont forget to take the bag off the alternator before starting, hope i helped
Old 01-13-2010, 09:47 AM
almost forgot, when you put the hi side fitting back into the new pump, make sure theres a new o-ring on it, getting a leak from that is unpleasant, and it wouldnt be a bad idea to flush the PS system while the lines are off and use fresh fluid
