Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
need help indentifying a 9 inch
Old 01-12-2010, 06:27 PM
98hardtopSS's Avatar
Default need help indentifying a 9 inch
This kid I work with has a 9inch out of a 4th gen that he wants to let go cheap. I beleive a 3 channel has the ABS in the pumpkin and 4 ch has the reluctor wheel in each axle....am I correct? If not let me know....thanks guys
Old 01-12-2010, 07:52 PM
DiabloFormula's Avatar
That is correct.....
3 channel will have the sensor on the pumpkin and will also have the reluctor wheel on the diff.
4 channel has the reluctors on the axles along with the sensors.
And if I remember correctly there is a way to convert from 3 to 4 channel or 4to 3 channel if you are putting it in a 4th gen that has the opposite.
Old 01-13-2010, 05:12 AM
I heard it was a pain do go from a 4 to a 3....you have to drill into the pumpkin I am assuming..
Old 01-13-2010, 05:29 AM
Yup, you would probably have to drill the housing somewhere, whats the rear you'll getting.
Old 01-13-2010, 07:32 AM
rear is 4 and my car is 3...moser 9in
