Anyone Running a pewter camaro with billet specialties drag set up
Old 01-13-2010, 12:27 AM
Zmg00camaross's Avatar
Default Anyone Running a pewter camaro with billet specialties drag set up
Just like the title says. and if i had my rear narrowed could i run a 5.5 bs without mini tubbing? I probly roll the fender.
Old 01-13-2010, 08:49 PM
LS1CMR's Avatar
not a drag setup but its a pewter camaro with street lites
Attached Thumbnails Anyone Running a pewter camaro with billet specialties drag set up-img00158-20091107-1724.jpg   Anyone Running a pewter camaro with billet specialties drag set up-img00159-20091107-1724.jpg   Anyone Running a pewter camaro with billet specialties drag set up-img00160-20091107-1725.jpg
Old 01-14-2010, 12:15 AM
Thanks for the pics looks awesome. anymore bump
Old 01-15-2010, 05:23 PM
1999FirehawkLS1's Avatar
You can cut up to 3in off each side of the rear and run a 4.5 BS rim 10in wide wheel and not worry about min tubing or moding LCA mount location or anything.
Old 01-16-2010, 09:44 PM
so if its narrowed 2 inchs each side i can run a 15 10 5.5 bs
Old 01-18-2010, 11:37 AM
LS1RedZ's Avatar
That pewter camaro above looks awesome!!
Old 01-18-2010, 03:31 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
Only problem you could run into is that if you narrow the rear say 2 inches, then you'd have to see if the 15x10/5.5 wheels will fit with your brakes. If you plan to keep stock brakes it could be a problem, it's something you'd have to find out before ordering.
Old 01-19-2010, 12:17 AM
Thanks for the replys yea i was thinking they make the 7.5 bs spec for f-body but what about the 5.5 BS, guess i have to do more research.
Old 01-19-2010, 02:59 PM
LS1Tech Co-Founder
They make two 15x10/7.5's, one is 93-02 F-Body specific and costs more.
Old 01-19-2010, 03:22 PM
Camaro396's Avatar
BS doesn't make a LS1 hoop for their 15x10 5.5" backspace wheel. So you will have to switch to Drag Brakes.
Welds new R/Ts in 5.5" backspace however, should.
Quick Reply: Anyone Running a pewter camaro with billet specialties drag set up
