rear suspension?
rear suspension?
the lateral bar that holds the rear tires straight what is the name of it? do the fail on a regular basis? i had to replace them on my 02 Bonneville but i figured that with 150000 (192000 now) that things would need replaced. the gp is only an 08 so i was kind of upset to hear some clunking down there.
Ok i'm a little confused, i went to bmr web site to check out the links and what they show doesn't look like the ones i replaced on the bonnie. the ones on the bonnies had a ball joint at one end so i thought these would also. i am going to take it over to a friends to put it on a lift and take a look.
so your saying with those theirs no rub?how long have you had them installed and bonneville isnt a W body so should be different ,my friend has an 04 bonne GXP and has a completely different suspension which i wish i could have..
after looking at those pictures it looks nothing like the bonnie. where the trailing arm mounts on the gp that is where the lateral link mounts and it has a ball joint there.
