rear suspension?
Old Jan 13, 2010 | 04:40 PM
1Fast7's Avatar
Default rear suspension?
the lateral bar that holds the rear tires straight what is the name of it? do the fail on a regular basis? i had to replace them on my 02 Bonneville but i figured that with 150000 (192000 now) that things would need replaced. the gp is only an 08 so i was kind of upset to hear some clunking down there.
Old Jan 13, 2010 | 05:01 PM
AlabamaGuy's Avatar
Control Arms, I believe.
Old Jan 13, 2010 | 05:12 PM
Count of Monte Carlo's Avatar
Trailing Arm- Body to Knuckle
Lateral Link- Knuckle to Center Support (Two of These)
Old Jan 13, 2010 | 05:17 PM
AlabamaGuy's Avatar
I was so wrong...
Old Jan 13, 2010 | 07:33 PM
neilownz's Avatar
BMR Fabrication makes upgraded ones. I have BMR lateral links and UMI Performance trailing arms on my car.
Old Jan 13, 2010 | 08:32 PM
Originally Posted by AlabamaGuy
I was so wrong...
Meow HSSSSSSSSS!!!!
Old Jan 13, 2010 | 08:39 PM
AlabamaGuy's Avatar
Meow HSSSSSSSSS!!!!
I'm a little scared right now....hahahahah
Old Jan 14, 2010 | 12:11 AM
blakss's Avatar
i knew about BMR's upgraded laternal arms but didnt know we had a other option for the trailing arms thanks neilownz
Old Jan 14, 2010 | 12:52 AM
neilownz's Avatar
BMR makes trailing arms too, but they would hit my tires.
Old Jan 14, 2010 | 01:21 AM
blakss's Avatar
yea thats what i was gunna ask you. heard that they all hit the tires because their not on an offset like the stock SS's ..have you had any problems.?
Old Jan 14, 2010 | 03:19 PM
1Fast7's Avatar
Ok i'm a little confused, i went to bmr web site to check out the links and what they show doesn't look like the ones i replaced on the bonnie. the ones on the bonnies had a ball joint at one end so i thought these would also. i am going to take it over to a friends to put it on a lift and take a look.
Old Jan 14, 2010 | 09:56 PM
neilownz's Avatar
http://bmrfabrication.com/W-Body.htm
http://www.umiperformance.com/catalo...roducts_id=293
Old Jan 15, 2010 | 01:10 AM
blakss's Avatar
so your saying with those theirs no rub?how long have you had them installed and bonneville isnt a W body so should be different ,my friend has an 04 bonne GXP and has a completely different suspension which i wish i could have..
Old Jan 15, 2010 | 09:37 AM
neilownz's Avatar
Look at my album.
https://ls1tech.com/forums/album.php?albumid=1753
Old Jan 15, 2010 | 12:18 PM
TheMonteMan's Avatar
what size tire are you running?
Old Jan 15, 2010 | 12:53 PM
1Fast7's Avatar
after looking at those pictures it looks nothing like the bonnie. where the trailing arm mounts on the gp that is where the lateral link mounts and it has a ball joint there.
Old Jan 15, 2010 | 03:53 PM
neilownz's Avatar
Stock size 235/50-18 Goodyear F1 A/S.
