Advice Needed
Advice Needed
Can you look at this setup and tell me if this is the correct way to install a purge setup with the regular nitrous solenoid? On the bottom of the nitrous solenoid there is also an output, does that stay closed off like it is in the second picture?
No, its not correct. The inlet will be the large 1/4" NPT. This is correct (minus the adapter w/ purge, which I'll get to later). The output to plate or nozzle is the bottom 1/8NPT port that you currently have plugged. Also, don't use that adapter fitting with the purge...you have a 3 port solenoid so the 1/8" nipple can screw directly into the side 1/8" NPT port (where you currently have the output hose). Hopefully that makes sense?
Nick
Nick
