TB Idle hole for 346 vs. 388?
Old 12-20-2003, 12:25 PM
2001CamaroGuy's Avatar
Default TB Idle hole for 346 vs. 388?
it takes "X" size of a hole for a 346 with a TR224 to idle at 800RPM.....
if that same engine is replaced with a 388 all bore short block and the same TR224 is used, will the idle hole be the same ("X"), smaller ("X" - __), or larger ("X" + __)?
Old 12-20-2003, 01:32 PM
MNC5's Avatar
With 400rwhp you just need a little programing. It's very easy to get much larger cams to idle without drilling a hole so why would you drill?
Old 12-20-2003, 01:42 PM
re-read what I wrote.....
I'm going to be pulling the motor and resleeving the block (Darton Wets) to make a 388 all bore. When the motor goes back in, it will have the same heads (have stg 3s) and will run the TR224 for a while (sleeper cam).
I want to know (just wondering) if the hole would need to be drilled to supply the larger CI at idle (would think so).
Old 12-20-2003, 02:00 PM
NoGo's Avatar
No, the hole will not need to be drilled.
If you already have cam tuning though, you will have to back down *slightly* on the IAC tables.
Old 12-20-2003, 04:30 PM
Bink's Avatar
The Man - is Back!
Seriously, I was beginning to wonder if everything was OK with you..figured family, work, business, FI....
Welcome back! I'm running late, for a Christmas dinner - I'll IM you later.
You da Man
joel
Old 12-20-2003, 09:24 PM
NoGo's Avatar
Work. Occasionally, I get dragged away for a couple months at a time doing the gas turbine bit.
I've been busy putting together my custom D1 setup as well.
Thanks for the welcome back
