iROTORS? or what...
As for the Brembo OEM. My race pads destroy them, but they never warp (even several millimeters thinner than spec). Guys have warped eradispeeds (and I'm sure there are a few sets of warped Brembos around as well). If you get enough guys beating on parts, somebody will break, bend, or destroy some of them.
Just remember not to park the car with the brakes real hot. Try not to slide into the driveway and park it, take it easy for a mile or two before you arrive. Try to cool things off a little first. This advice seems to have cured my problems with warped rotors on my 3rd gen F-body (I'd warp a set every 3,500 miles). After I learned to cool the brakes before parking the car, I quit having problems. This is not a cure all, just something that may help everyone out. They really are a product of how you treat them (brakes and pad and rotor life).
My thoughts.
I copied this from another post. I thought the brake warping info may be useful....
My thoughts.
If you got your rotors zinc plated, is the plating holding up well or are they starting to rust like the stockers?
BTW, I replaced my front with Autozone rotors for $39 a piece and they still aren't warped after 25K. The stock front rotors warped at 15K.
I personally believe that warped rotors are caused by idiot tire changers and the so called idiot proof torque bars and air guns they use.
I now refuse to let them put the wheels back on unless they use a torque wrench while I stand and watch them.
once spring comes or some 70+ deg temps im gonna get these and i am guessing some hawk hps pads cause im gonna repaint and redecal my brakes, they are chipping a little cause i didnt do a good enough job the first time, not enough coats. ill get some pics up when i get it all done...again lol how about the pads? hawk hps good? i dont want a real agressive pad but something good to stop with minimal dust and no warping of the rotors lol
