only when its cold
Old 01-23-2010, 08:39 PM
ls1rulesĦĦĦ's Avatar
Default only when its cold
i have a problem in a camaro, when the weather its cold the engine have a failure like a vacum leak and even intake explosions, but when the engine warms the failure goes, and when the weather its not so cold the cars runs good, i went to autozone and the scaner show lean mixture in the O2, so i sprayed the engine and nothings happend, and i cant see or hear any vacum leak then i clean the maf sensor, TB, IAC, but the failure still there, could be a O2 failure? low fuel presure? temperature sensor? im so confused... i have about a month whit this thing and i hate them
Old 01-23-2010, 08:51 PM
BaddBird's Avatar
I say you have a vacuum leak. The Pcm is not really looking at the O2s until it warms up and goes into closed loop.
Old 01-23-2010, 09:07 PM
ok im in the engine rigth now and i find something intereting a have no fuel pressure an the rail, its dry... and the engine start after second try i forget mentioned...fuel filter, fuel pump, clogged injector, fuel regulator ???? i have no gas smell so i dont think about a broke fuel line
Old 01-23-2010, 09:12 PM
1BADTALS1's Avatar
what? i read this 3 times and still don't understand what you are saying....
Old 01-23-2010, 09:15 PM
BaddBird's Avatar
I take it you have a gauge hooked up. If you do cycle the key from off to on 3 times waiting about 2sec in between each cycle and see what the pressure is.
Old 01-23-2010, 09:20 PM
i don´t have a gauge for now, tomorow i will try get one
Old 01-23-2010, 09:22 PM
haha sometimes i wrote to fast so i have some mistakes sorry
what i´m try to say there´s no fuel on the fuel rail
