only when its cold
only when its cold
i have a problem in a camaro, when the weather its cold the engine have a failure like a vacum leak and even intake explosions, but when the engine warms the failure goes, and when the weather its not so cold the cars runs good, i went to autozone and the scaner show lean mixture in the O2, so i sprayed the engine and nothings happend, and i cant see or hear any vacum leak then i clean the maf sensor, TB, IAC, but the failure still there, could be a O2 failure? low fuel presure? temperature sensor? im so confused... i have about a month whit this thing and i hate them
ok im in the engine rigth now and i find something intereting a have no fuel pressure an the rail, its dry... and the engine start after second try i forget mentioned...fuel filter, fuel pump, clogged injector, fuel regulator ???? i have no gas smell so i dont think about a broke fuel line
