DVD Player with monsoon amp and factory speakers
I'm going to be purchasing a aftermarket CD/DVD/MP3.. head unit. Will my new unit just hook right into my wiring harness and still use the amp? And where can I find an installtion kit where it has two slots so I can put my deck in and an EQ? Thanks!
im going a different route as i sit in traffic quite a bit so im going for a ps2 and tv monitor...however, from what i've found, as long as you get the wiring adaptor for the GM cars, so youd ont have to cut and splice any wiring (i think they are about 40 bucks) everything should work the same.
as far as the installation kit, check out www.crutchfield.com...they seem to usually have **** like this in stock, as far as it beign the best price that is suspect.
good luck
Travis
good luck
Travis
